It is currently Fri Sep 19, 2025 3:45 pm
PostPosted: Mon Apr 20, 2015 4:47 pm
Comments and suggestions welcome as always.
The Good:
Neck: maple
Fretboard: ebony
Truss rod: 2x carbon fiber spar only
Neck joint: bolt-on butt joint
Back and sides: magnetic pine
Top: Spruce
Electronics: Radio shack piezo buzzer
Scale lengths: 23.5" and 25"
Binding: rosewood
Finsh: wipe on poly
The bad:
1 Somehow the sides shifted in the mold when gluing the top which ended up slightly altering the shape and also altering the angle of the tuner slots at the bottom. I suppose I should have kept bending the sides until they sat in the mold without any spring.
2 It seems the sound hole corner was a little too much of an angle for the 1/8 inch rosewood binding, and it split.
3 A part of the binding moved while I was gluing it, so it dried sitting 1/8 over the bottom of the slot.
4 Both the top and bottom have a small crack. On the top this is due to the headless tuner section being a hair too tall I think. On the back, as soon as I planed the glued pine slats, they started cupping on me. I wrestled them down and glued them to the brace, but I think it eventually caused the crack.
Since I am working under a lot of limitations (no bandsaw, no thickness sandler) these pine slats are really handy. They come around 2.25" x .25
" x however long, which is kind of cool, if I ever wanted to build something big. I just glue the slats side by side, taking care to keep the correct orientation. I will say that these glued pieces are extremely hard for me to plane. Not sure why. Seems difficult to find a good direction for planing.
The Ugly:
I don't need no stinkin' transverse brace.
Uh, maybe I do.
Once I brought the strings up to tension I let it sit for a day. I noticed the neck move, about 4mm forward at the nut. I re-shimmed the neck and went thru this cycle several times. The top is definitely caving a little near the neck. Since I made some generous access panels on the back, I am hoping to add a brace. I don't mind compromising on a lot of things. But the action has to be low for my personal taste. I like it when people pick up my creations and say "At least the action is great."
Making an 8 string travel guitar is kind of a contradiction. A small body is going to be light, which will be a problem when you stick 8 tuning machines way out there on the headstock. This is one case where being headless definitely helps.
I definitely have some artifacts due to break angle, I can hear that phasing sound.
Most of the video was recorded with the mic, not the pickup.
Video and sound clip: https://www.youtube.com/watch?v=DJsLYHssxYI
These users thanked the author lactose for the post: pdolan (Tue Apr 21, 2015 10:14 am)
PostPosted: Mon Apr 20, 2015 4:54 pm
From the "How Different Is It"? file....
Well done.
PostPosted: Mon Apr 20, 2015 6:41 pm
First name: D
Last Name: S
Man, that is one of the coolest things I've seen!
It sounds great, and I really enjoyed the video.
I like your dowel form!
You have a gift for designing and building with available materials and tools.
Well done!
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: lactose (Mon Apr 20, 2015 8:23 pm)
PostPosted: Mon Apr 20, 2015 9:28 pm
Last Name: Eisenbrey
City: BELLEVUE
State: Washington
Zip/Postal Code: 98008
Very nicely done! I'm glad to see that the fear of being different has not affected this community... :lol:
PostPosted: Tue Apr 21, 2015 6:10 pm
Sounds great [:Y:]
PostPosted: Tue Apr 21, 2015 8:10 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Great sounding guitar, lactose! [clap]
Alex
Users browsing this forum: No registered users and 52 guests
